ohv180 tecumseh 18hp
Received 0 Votes
will run on choke, but soon as you try to take off the engine will die. I know carb. is clean. I know the gasket is on correctly. every port is open have had carb off 4 times rechecking and cleaned, blowed every port out with air but haven't solved the problem.
You still have a carb problem. There is one port still blocked off...probably the one behind the main jet. There is a tiny o-ring in the bowl where the jet goes in through the side. It presses against that o-ring and over time the o-ring swells shut. It has to be plucked out of the bowl.
Received 0 Votes
