rideing mower trouble
Old 08-04-10, 04:15 PM
gardenway by troy-bilt with 16.5hp briggs
model#-13AF693G118 911867 serial#-1C142B70374
(-motor-)-model#313707 type#0162-E5 code#-0202087E
problems-doesnt turn over,has fire to the solenoid,has new fuse,solenoid clicks as you turn key to start it.
battery good,starter good
Old 08-04-10, 06:16 PM
How did you test the battery and starter?
Old 08-04-10, 06:41 PM
test
i touched a screw driver on the solenoid across the 2 post and it turned over and started
Old 08-04-10, 06:53 PM
31YTech's Avatar
Replace the solenoid.....
Old 08-04-10, 06:59 PM
mower
what would cause the burning of the fuses?
Old 08-04-10, 07:32 PM
31YTech's Avatar
A shorted solenoid or bad/burnt contacts in the fuse holder it's self or a bad/rusted battery (B) post on the back of the ignition switch, The solenoid is faulty from your description so replace that and see how the fuse does....
