Ryobi Gas trimmer can not start
Received 0 Votes
Hi All friends,
I have an old Ryobi gas trimmer (725R 31CC). It had some starting problems before, if you pull some 10-20 times, it may start, once it started, it ran well.
About 1 months ago, I went to a shop, bought two gas lines which was broken, prime bulb, spark plug and changed them, after that I used once. it started and finished my yards. Now I tried to use again, in last three days, even I pulled so many times, there is no any starting sign at all (the pullll sound and smoke etc). I unscrewed the spark plug, I found there is no any sign of gas in it, I remembered before when I unscrewed the spark plug, there is some gas, do this mean something blocked the gas from going to the burning space?
I checked the gas line, both looks good, when I press the prime bulb I can see the gas "loop" moving in the two lines.
Any suggestions, thanks in advance!
Thanks
BG
Thanks
BG
Welcome to USA Zama
Welcome to walbro.com
