Poulan Preadtor please help
I had to fix my pull rope. When I was taking apart the chain saw to get the cover i accidently took out the throttle screw. I put it back in and now the chain saw chain just spins. when i take the brake off. how do i fix this.
If the engine is driving the chain and the throttle screw you changed holds the throttle open, the idle is too fast. Just turn the screw out until the chain stops spinning.
