Yardworks 4.5 carb. linkage Help !!
Old 08-09-10, 07:14 PM
W
Hi I had the carb. off to clean it and now I can't get the two linkage rods right.
Did a little searching on google and can't seem to find anything ?
Thanks for any help you can offer.
I found these numbers on the mower deck, didn't see anything on the engine..
11a-413f515
060-1603-6
Wayne.
Old 08-09-10, 10:16 PM
cheese's Avatar
Received 94 Votes on 87 Posts
Do you know what kind of engine is on it?
Old 08-10-10, 05:08 AM
W
It's a Tecumseh 4.5.
I can't seem to find any numbers on it !?
Old 08-10-10, 03:34 PM
31YTech's Avatar
Hello Wayne,
Take a look at this thread, It should cover your linkage problem;
http://forum.doityourself.com/outdoo...long-help.html
Good Luck
Old 08-12-10, 07:31 PM
W
Thanks for the pictures I plan on tinkering with it tomorrow (the beginning of my long weekend).
One thing I noticed from the pictures you supplied. It looks almost like mine but slightly different. My lawn mower (Yardworks4.5) doesn't have a throttle control. Both rods/spring attach from the governor arm to the top of the carb.
Everything looks almost the same as the pics with the exception of the throttle arm.
I haven't had any time but I plan on tinkering with it tomorrow.
I should have took a picture, I need to try and remember that for the next time Finding the parts manual would be a bonus.. I've been searching. Any more input is welcomed.
Cheers
Wayne.
Old 08-13-10, 04:13 AM
31YTech's Avatar
Wayne,
If you don't have a throttle control the link with the spring will hook to a stationary tang/bracket next to the carb.
You can download a complete service manual for your engine here; Toprake - A Cut Above
Good Luck
Old 08-13-10, 08:49 AM
BFHFixit's Avatar
Also if you have the tang instead of throttle, it goes on the intake/carb bolt closest to the engine.
I have had some come in with it installed on the outer bolt after attempted repair, and the spring tension is too much and the mower will not start.
Old 08-13-10, 08:15 PM
W
This is exactly what I have done. I will move it to the inner bolt tomorrow.
Thanks for the input.
Cheers
Wayne.
Old 08-15-10, 08:10 AM
W
Cheers
Wayne.
Success ! Thanks for all the help. Love this place !
Cheers
Wayne.
Old 08-15-10, 08:18 AM
BFHFixit's Avatar
