Simplicity 3415s
Old 08-21-10, 06:02 PM
Simplicity 3415s
I have recently acquired an old simplicity 3415s lawn tractor from A friend of mine (he knows I like to fix things). I want to know how to check if the engine is safe to run. It has no rust buildup on the engine block if that helps. Also, I can't find the engines' oil pan release so if anyone knows that would be great.
Old 08-21-10, 07:53 PM
31YTech's Avatar
Hello thedancingman43,
Can you give us a engine model number ?
IIRC they used Briggs/Kohler and Wiscosin engines....
Old 08-21-10, 08:23 PM
Its a briggs and straton engine
Old 08-22-10, 06:51 AM
31YTech's Avatar
Well thedancingman43,
In my quest to find out which Briggs engine you have (no numbers posted) I stumbled across a PDF Owner's/Parts Manual which may come in handy.
As for the oil drain, It's on the end of the pan. It could be a regular square head pipe plug or a flush square drive plug, Simplicity also could have installed a street 'L' with a pipe plug dropping it right inside the frame rail.
How long has this machine been sitting around without running ?
Old 08-22-10, 10:24 AM
I don't know how long the engine has been sitting around for, but my best guess would be more than ten years. However, I do know that the cylander is free and moving and is attached to the transmission.
