Bagging grass
Received 0 Votes
Bagging grass
I've got a Troy-Bilt Bronco and I got a twin bagger a couple of weeks ago and when the weather was dry, it works very well. However, if the grass is just barely moist, it really clogs up the discharge chute bad. Is there anything I could do about this? It is very aggravating!
Jack,
Fluid Film is widely used in the commercial lawn and garden industry by thousands on other message boards I frequent.
A light spray from a aerosol can or light coat brushed from a gallon can on the bottom of the deck and inside the plastic chute will reduce grass sticking/build-up.
The more applications the better it works, If you like I can PM you some links to read first hand experiences......
Received 0 Votes
Much depends on the location and climate.
In the grass growing season here (June, early July), you may have to cut 3 times a week if you have a healthy lawn. I tried to cut one day, let the grass dry and bag it the second day. It could be a real nuisance, but occasionally I could mulch it and not bag. After that, in the drier and hotter months, I mulched everything and never had a problem since weeds could not survive in a healthy lawn.
Just keep the blades razor sharp and don't go too fast.
Dick
Dick
I live in the northeast US where the yearly avg. rainfall is approx 40 inches. I have had no success with baggers not clogging, just too wet, the grass itself is too wet. I have seen others bag with some success, but their turf was either dryer or cut on 3 to 4 day intervals, something I can't do. So as the others have said. it depends on climate, drainability of your soil, type of turf, are you using "high lift" blades, and are they sharp?
