Kohler CV730S-0017 Running Rich
Received 0 Votes
How is it possible for an engine with no air/fuel mixture setting to run rich? The butterfly is wide open, and it used to run fine.
Any ideas?
Any ideas?
Received 0 Votes
They can run rich if the air filter is really dirty.
When the throttle control is moved from slow to fast speed it shoots a little extra fuel into the carb venturi area. This reduces stumble on throttle up.
If a pin hole develops in this diaphragm engine vacuum in the venturi can pull constant extra fuel, This can cause a rich running condition.
