Ariens EZR1742
Old 08-30-10, 07:05 AM
E
Ariens EZR1742
The 30 amp fuse connected to the starter solenoid on my zero turn keeps blowing when try to start the mower. I checked for shorts and any grounding issues and found none. Any ideas as to why the fuse keeps popping?
Old 08-30-10, 06:23 PM
31YTech's Avatar
Hello ehyw69,
Does this fuse pop soon as you turn the key to the run position or only when you go to the start position ?
Old 04-19-12, 11:58 AM
Did you ever figure out what was going on? My Ariens zoom 42 is doing the same exact thing. Any help would be appreciated. Thanks
Old 04-20-12, 07:05 PM
31YTech's Avatar
Hello jamedawg32,
Can you answer the same question I asked ehyw69 ?
And, Post a model AND serial number off your unit along with the engine model AND spec numbers ?
