Honda HT3813
Old 08-30-10, 09:49 AM
A
Honda HT3813
Problem with PTO
When I engage the lawnmower blades the blades turn only at about 50%. I've checked the belt tension, pulleys and looks good. When I slow the engine down from say 90 % to 20 % it sounds like the blades are not following. I've also checked the belt tension on the front of the mower. Any ideas?
Old 08-30-10, 07:17 PM
31YTech's Avatar
Hello arokces,
Sure sounds like you need to check your PTO clutch adjustments;
Good Luck
Old 08-30-10, 07:41 PM
cheese's Avatar
Received 133 Upvotes on 122 Posts
Agreed. In my experience with these, the clutch material is de-laminating from the clutch and breaking out, causing slippage. These mowers are pretty old now, but sweet and quiet running machines. If you need a clutch, they are pretty pricey last time I checked. Maybe/hopefully all you'll need is adjusting.
