Craftsman 18.0 cuts out when clutch engaged
Received 0 Votes
This is a Lawn Tractor, mdl 917.272761
I have the schematic of the electrical wiring. I have already jumped the seat. I bought a new switch for the clutch but it is almost impossible to remove it without tearing the tractor apart. It doesn't matter whether I release the brake/clutch or the attachment clutch, both will shut down the engine. I have already unplugged the clutch switch and plugged in the new switch with the relay open and no dice. Same goes for the attachment switch. I am trying to isolate whether I have a switch or solenoid problem. Any info on how to test with meter would be appreciated before I order new parts. At the ignition switch, I am trying to figure out what could kill the engine or is one of these points a kill swith. I would appreciate any thoughts you may have or experienced the same condition.
Hello mydogisjd,
How did you jump the seat switch ?
I will assume you just put a jumper wire across the two terminals in the switch plug connector ?
If so that's not a proper way to test, If you look at the plug connector there should be a little nub sticking up between the two terminals.
This is another "switch" (lower pic below), Wrap a wire tie around this plug connector (upper pic below) to hold this nub/switch in. Don't connect the two terminals together then try your clutch again, If it now operates replace the seat safety switch.
Good Luck
Good Luck
