B&S 6.5 HP - Running Rough
Old 09-02-10, 11:52 AM
My 6.5 HP Briggs and Stratton Model 123K00 is running rough. Starts fine. Then idles up and down slightly, but enough that its obvious and not mowing a clean path on my lawn.
I've pulled the carborater and sprayed all jets, ports, and throttle body with carb cleaner. Replaced the airfilter-side gasket. Replaced the intake manifold in early spring. This is the model with the fuel bowl under the carb.
What am I missing? Cracked intake manifold? Leaking intake gasket?
Thanks in advance...Greg
Old 09-02-10, 04:12 PM
You can check for the air leak by spraying/dribbling carb/brake parts cleaner along the mating surfaces behind the carb, if the engine tempo changes you have found a leak. Have a good one. Geo
