weedeater drains gas
Old 09-06-10, 05:39 PM
weedeater brand weedeater model GTI 18,rebuild carb and gas drains from tank thru carb,weedeaters runs great, has primmer bulb on it not sure if it came from factory because i had to drill a hole in the gas tank for the second fuel line to the bulb.seems to be mixed parts from another maybe
Beer 4U2
Old 09-08-10, 05:54 PM
cheese's Avatar
I would usually say I think the needle valve is not seating well, but if it's not put together the way it's supposed to be, there's no way to know what's going on. I suppose if the lines are connected properly to the carb, I would still think the needle valve is bad. If this happens to have a check valve in the throat of the carb, this could be leaking as well.
Old 09-09-10, 03:57 AM
Interesting, all the GTI's, (the older Weedeater models) I've worked on didn't have primer bulb. Just repaired one a couple of weeks ago.
Was a different carb fitted to unit??
I would do as Cheese suggests......
hth
Old 09-09-10, 06:25 PM
i do think a different carb was fitted to the unit.i know as you stated that older Weedeater models didn't have primer bulbs.thats why i had to drill a hole in the tank to retro fit.i will check needle valve and check valve and report back
thanks
