weed eater help please
Received 0 Votes
ok.. i work on a computer all day and am not mechanically inclined.. my hoses on weedeater broke so i replaced them all.. i took a pic to remind myself how to put em back, but deleted it.. i tried a combination and it turns on for about 20 seconds and it turns off.. if i keep throttling it-it will stay on.. but as soon as i let go of throttle it turns off.. i used fresh new gas and oil that i mixed that morning..i have a Poulan Pro PPB250E 31cc 17-inch Gas Trimmer.. below are pics of the carb with letters to identify each hose to assist in explaining to me.. i currently have hose "C" goto the filter inside the tank.. thanks for the help fellas
thanks for the help
thanks for the help
Received 0 Votes
take the lines off the primer bulb-
use your finger tip to decide whitch port on the bulb - is suction. that is the one that goes to filter - pressure goes to carb- last 1 is return to tank.
as you push on bulb - you should see fuel & bubbles move throuch the lines - back to tank.
I believe the line with filter in the tank goes to the carb, other line from carb goes to suction on primer, pressure on primer is return to tank...
Received 0 Votes
i was going by the routing on my 'wead eater' brand.
i certainly don't want to steer him wrong.
Standard for most all 2 strokes I have worked on, the Primer is actually a "purge" more so than a primer. It is meant to purge the air from the lines and the carb before starting.
Most also use a separate "choke" for cold starting.
Received 0 Votes
that is what i meant by - see fuel & bubbles move through lines
Received 0 Votes
so.. the one that suctions from the bulb.. that is the one that connects to the filter? than where does the other port from the bulb goto?.. than theres a 3rd one that goes into tank too i think
thanks again
thanks again
Received 0 Votes
hth.
