Briggs & Stratton Engine on my Toro Zero Turn
I went out to start my mower and when I checked fuel, it was empty. Odd I thought since I didn't think I emptied it last mow. Had to jump start battery since it has been a bit cold. Filled gas, came back and it was leaking out. upon further inspection the air vent next to air filter was full of gas. when I googled it, B&S website had the same question and they said it might be a stuck float. When I am trying to get the carburetor off, I don't understand what the thing is on the very bottom or how to get it off. It isn't a screw. see the picture below. anyone know what it is and how to get it off? There is an electrical wire attached to it, which i have removed.
http://www.shop.com/698620+791886+Br...69945-p+.xhtml
I don't see your picture, but it sounds like a fuel shutoff solenoid.
Make sure you change oil in that engine before you start it.
changed link to a picture
do you know how to get it off? i have tried unscrewing it but it doesn't seem to be coming looser.
Hello mytorozeroturn,
There are two flat places on the shank just under the float bowl where a open end wrench can be placed for removal.
Good Luck
Good Luck
Previous Thread
Next Thread
