Shifting problem
trs4594's Avatar
OH
09-16-10, 02:27 PM   #1
Shifting problem
I have an MTD yard machine mower, 38" cut 13hp.
Model #13A4662F129 483-839
Serial #1D182B80186
The shifter will move into F and R but it doesn't feel like it engages, and of course, doesn't go in either direction. I haven't had the chance to spend any time with it so I haven't done anything yet.
I haven't used it since spring and no problems with it then, and it has been kept in the garage/under roof. Could this be something simple like a linkage or lube issue?
Appreciate any thoughts, guys.
mla2ofus's Avatar
TX
09-16-10, 03:14 PM   #2
Is the v-belt from engine to transmission still there and tight?
Mike
trs4594's Avatar
OH
09-16-10, 04:33 PM   #3
When I can get back to it, that's the first thing I'll check, thx. Anything else I can look for?
trs4594's Avatar
OH
09-17-10, 10:38 AM   #4
OK.
Blocked up the back end, rear tires off. Central cover plate where shifter is located is off. The shifter is simply a bar bent to go back to the trans, where it is bolted to a small plate that is cotter pinned to a split barrel that slides into the trans.
There are three belts; the lower one only for the mower deck which engages when the deck is dropped. The other two meet at a dual pulley in the middle of the unit, which seems to act as a relay point to transfer drive from the engine to the trans. Both belts are there and snug.
I started it up and played with it a little, the shifter seems to sometimes engage the trans and the axles turn, and at other times it seems like it won't shift 'in'.
Did I miss anything?
