B&S model 130202 5hp won't crank
Received 0 Votes
I have a B&S model 130202 1907-01 5hp engine that won't crank with out using starter fluid initially. I have replaced the fuel diaphram to no avail. The carb has 2 pipes going down into the fuel tank, both having filters on the end and don't appear to be stopped up as I can blow through them. The longer pipe goes down into the gas and the shorter pipe goes into a small resevoir with nothing in it. Should there be gas in the small resevoir or what is this shorter pipe for. I can pull and pull with no gas being indicated in the carb. Any ideas?
Received 0 Votes
IMO one of three things. The long tube that goes to the bottom of the tank is plugged, the check valve in the bottom of the long tube isn't working(not sure if that one has a check valve) or the fuel pump diaphragm located on the side of the carb has a hole in it.
JMHO,
Mike
JMHO,
Mike
Received 0 Votes
If the small fuel bowl is empty, then the fuel pump on the side of the carb isn't working, or the bowl has a hole rusted in it and the fuel drains right back out as the pump pulls it in.
