Chain saw starts, stalls and leaks gas
Received 0 Votes
My abused 35+ year old Homelite Super 2 14" chain saw stalls after running a few seconds. Some gas then leaks out of the housing. The saw now refuses to start after stalling. This behavior started after successfully cutting a few tree limbs. Any suggestions on the cause of the problem?
Chances are you will wind up with the carb off, so may as well get it over with IMO. Get the make and numbers (we can help with that) and make sure a kit is available.
Open it up check it out...stiff rubber no doubt and who knows what else ya may find.
Received 0 Votes
Thanks again BHF. Found the carb ID and the manual. The manual gives good info; however, can you advise me where to find rebuild guides or tutorials? This is my first rebuild.
Lot of folks seem to be finding a need to make you-tube videos of this type of stuff, However, many I have seen are not completely accurate or seemingly knowledgeable.
Not too much to it really, take some photos if you can before you start. Note all connections whether it be hoses, wires, or linkage. Disassemble noting how the gaskets stack and where the parts are. Count the turns on the needles and then remove them also. Get some canned carb and choke spray from auto store or walmart, spray through all passages and blow with compressed air and reassemble.
Received 0 Votes
BFH and Joe, I found the fuel pump cover screw loose when inspecting the carb. Put the saw back together and it now runs just fine. It all makes sense (stalling and fuel running out). I will still get a carb kit since the saw is so old. Now that you have enlightened me on carb basics, I intend to rebuild the carb on a Poulan Pro 422 leaf blower that will not run. I suspect a gummed-up carb. Thanks so much for your help. You saved me $200 for a new saw. Who said Homelite saws were junk?
