yard machine run bad
Received 0 Votes
model 219707- 0198- E1
cleaned carb,its running rough,runs up and down at fast,carb pops,at idle the motor shakes like its about to come apart
Cleaned carb & installed a kit?? Have you tried a New plug in it yet??? If you didn't put a kit in it, I think it's kinda like washing you feet with your socks on,,,LOL... Sometimes it works,,sometimes it does'nt... Clean it again in a bath type cleaner,, rinse with a spray type cleaner & blow clean with compressed air & install a new kit..Also verify the intake isn't cracked & the gasket & bolts to the engine are tight & nothing is drawing air..
Received 0 Votes
yard machine still run bad
model 219707- 0198- E1, Cleaned carb again and installed a kit,back fires and runs rough,choke it a lil then put choke off,it levels out and run great
