Craftsman throttle diagram needed!
Hello all,
I have an older craftsman 12.5 hp riding lawn mower model 917.255581. B&S engine # 286707. Removed carb for service and left the govenor and throttle linkage connected to the throttle bracket and the choke and throttle linkage bar popped off. Need to find a diagram of how the linkage hoookes to the bracket. please help!
longer link with no hook goes from top of governor (staggered end) to throttle plate on carb (hook end) Choke rod is one with big loop on one end and hook on other. Hook goes in choke plate and loop end goes into throttle bracket and gets pushed when throttle moved to choke, assuming it's like the sear 12.5 I just took apart. Sorry no pic.
Hi 38racing, Thanks for your quick response! No pics needed! Your description was very clear. I am certain that it is identical to the one you jut took apart. Thanks again!
