McCulloch Chainsaw won't start
I have a Mcculloch gas powered chainsaw. I'm having trouble starting it. Prior to now I never had any problems starting and using it and I have only used it a dozen times max. I have changed the spark plug, taken apart the carb and cleaned it. Cleaned the fuel filter. After many many pulls I finally got it to turn over. It ran for a while then when I shut if off - no luck in starting it again. I've pulled the spark plug and verified spark. I do notice that when I'm pulling the starter gas appears to be running onto the ground ??? I tried to see where where it is leaking and appears to possibly coming out of the muffler. Anyone have advice or suggestions. Thanks
If it's an older saw, you may need to put an overhaul kit in the carb. The diaghragms get stiff & won't operate the meatering lever correctly.. When you find what carb you have, go to their website & check the manuals for proper adjustment of the meatering lever, or use the old one if it doesn't show any signs of wear.. Roger
