Honda EM3500S Generator Idle Down Issue
Received 0 Votes
I have searched the threads here and haven't found an answer to my problem. I was given a Honda EM3500S generator from my brother-in-law and it has run fine up until this year. The issue is that when you run it and turn on the auto throttle it seems to hunt for idle. I did find that it was idling too low on full and only putting out about 116-117 VAC. I adjusted that out. New plug, drained and clean the petcock bowl. When you apply a load to it it comes up to speed and stays there. When you take off the load the auto throttle drops low and then tries to recover, RPMs and voltage bouncing up and down. Any thoughts? Thanks to all in advance for any help. This is a great forum and I have enjoyed reading the posts.
The carb is probably getting a little varnished, before removing it and giving it a real cleaning, I would suggest adding some SeaFoam or Chevron Techron to the fuel and running it, they are both very good. Have a good one. Geo
Received 0 Votes
Thanks Geo! That is what I was thinking about trying that. I have used Seafoam on a few of my older motorcycles that don't get ridden much. I am almost certain that I did put Stabil in the generator but even that is only good for so long. I hate to take the carb off/apart as I never seem to get everything back together correctly. Digital cameras are great though for taking pictures before and during dismantle so that you can look to see how everything goes back. Thanks again.
