snowblower not throwing like it used to...
Old 12-08-10, 12:40 PM
mik
mik is offline
My Craftsman 9HP/ 28" snowblower is about 8 years old and this winter it hasn't been throwing the snow anywhere near as far as it used to. It now only throws it about 8-10 ft, whereas it used to throw it at least 20 ft. No loss in HP or engine rpm or performance; new fluids & spark plug annually, chute is always clear before I start using it. Any clue (I know- difficult without seeing it) or suggestions for common causes?
Thanks
Old 12-08-10, 03:42 PM
Snowblower
Make shure that your belt[s] are not slipping, or the pulley/shaft conection is secure. I spray silicone, or liquid wax into the auger, fan
, and chute and that helps greatly. Just be careful, Its best to do it while the machine is not running, but in an emergency I have poured liquid wax on the snow and run the blower right through it, just be carefull to not get it on anyone or anything that you might regret later.
Sid
Old 12-08-10, 04:16 PM
Belt slipping or worn bearings on the auger and/or impeller. Check the belts first. Cracking or chunks gone or just worn out.
Old 12-23-10, 06:17 AM
mik
mik is offline
The only thing that came with it was a very basic instruction manual; any hints on where (online) to locate a more detailed schematic or repair manual?
Old 12-23-10, 07:59 AM
BFHFixit's Avatar
You'll need the model number to find parts listings here
Old 12-31-10, 12:43 PM
Manuals online or pdfmanalsonline.com Just google it.
Old 12-31-10, 01:03 PM
lawrosa's Avatar
Super Moderator
Did you check if both augers are spinning? I broke a sheer pin on one side and it reduced the throw.
Mike NJ
Trackbacks are On
Pingbacks are On
Refbacks are On
