Ariens 522EC Snow Thrower - Repair Manual Available? (Change Fuel Line)
Old 12-12-10, 08:58 PM
D
Ariens 522EC Snow Thrower - Repair Manual Available? (Change Fuel Filter)
I have an Ariens 522EC Snow Thrower with a Tecumseh engine that is about 5-7 years old. It won't start and I'm wondering if it is a clogged fuel filter. Does anyone know if there is a service manual available free on-line or at a reasonable cost so I can get some direction in repairing it?
Old 12-13-10, 06:18 AM
I
you can get it from Ariens.com. but what you really need is a Tecumseh manual. The only gas filter used is a screen inside the gas tank. Your problem is most likely varnish in the carb. This E-10 gas starts going bad in 30 days. You will need to remove the carb, take it apart, soak it in a carb cleaning solution, wash off with water, blow out ALL holes with compressed air, and install a new kit.
Here is the Tecumseh manual
http://www.cpdonline.com/692509.pdf
Old 12-13-10, 06:32 AM
D
Thanks
That makes sense. Thanks for the help.
