Poulan pole saw
Old 12-30-10, 05:59 PM
Poulan pole saw
hello all I have a pole saw I haven't ran in about 6 mnths I started it up today and it started up fine in the full choke or the start mode ( I think poulan calls it the high idle) I let it idle high at more than 30 seconds and as soon as I switched it to run it would idle for a couple of seconds and then quite also when I did get it to idle just alittle longer and as soon as I squeezed the gas the saw died every time so I just had to start the saw in the start mode and then just hold the gas down all the time what are some things I can do to help fix this
Old 12-30-10, 06:13 PM
oo it seems like the engine just isn't big enough for the pole saw for instance when the saw goes down to an idle and I want to speed it up it to cut it seems like the engine has a hard time getting the chain going but once it gets going it does a good job on cutting its the 25cc engine what do yall think about this? do yall think the engine is to small for the saw?
Old 12-31-10, 12:19 AM
cheese's Avatar
Without actually being able to listen and hear how it is running, I think I'd suspect the carburetor. Try backing out the mixture screws 1/8 turn or so.
Old 01-01-11, 08:57 PM
where would the mixture screws be at?
Old 01-02-11, 01:02 AM
cheese's Avatar
on the side of the carburetor...2 small screws side by side.
