Generators w/ Gen Head that includes a shaft
Received 0 Votes
Hello all,
Here is the story I have a 14hp Kohler Vertical Shaft Engine mounted on an old commercial mower frame. I thought this would be a great generator as it would be easy to move since it has its own transmission and I can turn the generator off an on using the magnetic clutch for the belt.
So after looking for old generators people may want to get rid of with bad engines, I came across a big issue, most do not have a shaft protruding from the gen head that I can use for a pulley. I may need to upgrade any bearings in the head doing this
Question 1: So is there any generators out there that have a gen head which has its own shaft protruding?
Question 2: Are there any shafts I could use for gen heads that don't have their own shaft?
#1 Yes look here:
Generator Heads | Generators | Northern Tool + Equipment
These need to run horizonal
#2 no
AJ
#2 no
AJ
