craftsman 5hp snowblower
Received 0 Votes
need help have big amount of snow and the snowblower is not running right. it is a 5hp craftsman blower about 12 years old and it start fine but as soon as it get under load it start to bog down and almost die if I don't let off. it has run fine in the past un till this year. I have allways drained the fuel every season. I have even tried fresh fuel. don't know what to try next.
Thanks in advance Chris
Usually it's varnish build up if the fuel system / fuel has been kept clean.
That being the case I would put Sea Foam in it. It will probably clean it up. Usually you'll see a difference within an hour of running.
You still need clean fuel, good venting on the cap, good lines to the carb and a good plug.
You can get Sea Foam at Walmart and most auto parts stores.
Received 0 Votes
I noticed fuel leaking from the fuel bowl and took it off and the gasket fell of in about 6 different pieces wood that have anything too do with it running wrong. am going to wal-mart today and going to try the seafoam also.
No, but having to make an assumption that the fuel leaking was more of a slopping in the bowl due to movement of the blower, as opposed to an overly full float bowl.
Of course the gasket should be replaced.
Received 0 Votes
tried the seafoam and run it about three hours and still does the same thing. a friend said it might be the governor. I think i will remove the carb and take it apart and clean it that way.
Received 0 Votes
help
Just purchased a 5/20 craftsman. It will not start. I have a good spark. good gas flow to carb etc. I lossen the high idle jet at the bottom of the bowl and no gas comes out. If I remive the jet, should i not have gas coming out.
Seems like the engine has good compression. The choke was jammed shut at the carb so I had to loosen up throttle and choke with intake spray which worked fine.
What can I check next. Seems like the spark plug is not wet. Seems like no gas geting to plug.
The blower does have a ket start. I get the spark regardless if key is on or off. The ignition was off the machine when i purchased. i just hooked the one wire up to the one wire i found stranded and figured all should be good to go.
ANyone have any good ideas on where to go next? Do i need to pop thr carb off and do a good cleaning etc?
granatnl
granatnl
Received 0 Votes
cured my problem bought a 6.5 hp greyhound engine from tool harbour freight. it will throw snow farther than the original motor and it starts really easy. it started on the first pull and it was 6 degrees out. all the pulleys fit right on it and the motor mount hole were exactly the same. only took about 20 minutes to swap.
