cub cadet rzt 50 weak steering on left hydro
Received 0 Votes
I have a cub cadet rzt mower that the hydrostatic on left side isweak steering and whinning, I put new belt on ,tried adjusting linkage arm but still weak. I dont see any place to add fluid and what type to add , it sounds just like a car sounds when its low on power steering fluid gets harder to steer the longer you mow help please
There is probably a vent hose that threads into the top that you can unscrew to add some oil. This has hydrogear units on it that are considered to be sealed for life. Is there any evidence of fluid having leaked out (wet oily spots on the tranny)? Check the relief valve area where you pull the little rod so you can roll the mower. Grass can pack around the valve and make it so that it doesn't go all the way back in when you move it. These trannys take synthetic 20w-50 oil.
