Snowblower issue
Old 01-04-11, 05:59 AM
Snowblower issue
This past storm I helped my neighbor by snowblowing his driveway. What i didn't know was that there was a huge rock in the driveway. When I hit it the shear pin did not break, but the auger fin bent.
I tried to bend it back with a vise grip and then a hammer and it wouldn't bend back. Any ideas on how to bend the auger fin back?
Old 01-04-11, 06:57 AM
lawrosa's Avatar
Super Moderator
Im not sure how to bend it back. I would say you may have to heat it to almost glowing red.
But besides that the shear pin should of broke. Are you sure the shear pins were not replace with a hardened bolt or something. I would check this. I am suprised you did not twist the crank.
Mike NJ
Old 01-04-11, 07:03 AM
I bought it new and never replaced the shear pins since i've had it (I know they are made to break so something like this won't happen).
The tip of the auger is bent, so it should be simple to heat and maybe bend with a vise grip or something. I think you're right that I might have to heat it--the steel is very strong.
Would the machine work even though the tip is bent? (near the center gear case)
Old 01-04-11, 07:12 AM
lawrosa's Avatar
Super Moderator
It should work. It only pulls the snow toward the second stage impeller. How new is it. You may just get a new auger under warranty. You may just leave it as is. The bend may not affect anything.
Mike NJ
Old 01-04-11, 08:22 AM
The shear pins probably didnt break because the augers are rusted to the shaft. You should pop the shear pins out and try to manually turn the auger with the machine off and plug wire disconnected. You may have to free up those augers and lubricate when weather permits.
Old 01-04-11, 08:53 AM
The machine is about 4 years old. I will check to see if the auger is rusted to the shaft. I may see how involved bending the auger back is. I may just wait to see how well it works without bending it.
Luckily the augers is not hitting the housing, it's just bent inwards right near the center gearcase.
