tecumseh 8hp engine
Old 01-09-11, 06:52 AM
K
tecumseh 8hp engine
Have a tecumseh snow king engine 4cycle Lh318sa that when started puts and only stay running with choke in middle and idle has to be high.black smoke upon startup and gas leaks when priming it.did this since new .should it run smooth or is that how they run. dont know much about small engine repair but i can change spark plug(lol). any advise to what can be done.nothing done as to changing anything since new .thanks k i should say it does the job but just wondering
Old 01-09-11, 07:39 AM
I
Your main jet is clogged. The main jet is the "bolt" on the bottom of the bowl. You will need to drain the gas or shut off the gas first. There is a tiny pin hole in the threads that everyone seems to miss. It is only 1/2 mm and hard to see even when clean.
Old 01-10-11, 03:43 AM
K
cleaned the bolt and worked calming down sputter but when in the run triangle it starts acting up again it even stalls like not getting gas.then put at fast setting and it starts the problem sputter again but runs. when using the thrower are you supposed to use the fast setting when clearing snow.
Old 01-10-11, 09:40 AM
I
The main jet is still not clean. That tiny hole is still clogged which is what is causing the problem. And yes, the snowblower is made to be run at full speed.
Old 01-10-11, 01:10 PM
G
Received 28 Upvotes on 27 Posts
Refer to the picture below, it is the top hole indy is refering to, the bolt may not look exactly like the one pictured, I use the wire from a twist tie to clean it. Have a good one. Geo
