MTD snowblower won't start
I have an MTD 5/22 snowblower with an electric start. It has been dfficult starting this season, but once started runs perfectly. Did a great job clearing our 24 inches of snow Wed. Now it won't start at all. It is getting a spark and after trying to start it several times the spark plug is wet so I assume it's getting gas. The gas is new and is high test. Any suggestions?
There is a choke and a primer (rubber push button). Once running, I have to leave the choke and the throttle in full position or it will stall. I have tried fewer primes and it still won't start. I'll try reducing the choke when I try to start it.
Sounds like the carb is dirty or getting a varnish build up, you need to clean the carb, however you might get lucky, put some SeaFoam in the fuel(available from most automotive stores) and run it, the SeaFoam will desolve the varnish, good luck. Have a good one. Geo
