Ariens 8.5 hp ST5520 Won't Pull Start
paul3624's Avatar
MA
01-16-11, 05:56 AM   #1
My Arien's doesn't seem to want to pull start. Will start fine with the electric starter, but but won't start with the rope. It's a Briggs & Stratton engine.
Thanks,
Paul
Pilot Dane's Avatar
NC
01-16-11, 06:27 AM   #2
It's probably that you are not pulling the cord fast enough. The engine has to be turning a minimum rpm to create enough draw through the carburetor, get good compression and generate a proper spark.
paul3624's Avatar
MA
01-18-11, 01:49 PM   #3
Pulling as hard and fast as I can, but still no luck. Will pull start after it's warmed up after electric start, but nothing cold.
Paul
geogrubb's Avatar
MO
01-18-11, 03:13 PM   #4
It's probably the oil being thick from being cold, you might change to a 5W30 or 10W30 oil which would make it easier to turn over when cold. Mine has straight 30W with no electric start and I must give it a shot of starter fluid as a helper because I can't turn it very fast when cold and it is just a 5hp. Have a good one. Geo
