mtd snow blower, auger won't turn
Received 0 Votes
MTD snow blower
model 316e640f000
It will start up, idle, and go when I engage the traction drive. Once I engage the auger clutch the motor shuts off and the auger won't turn. The sheer bolts look to be okay. I took off the cover to see the pullies. Restart the motor and engage the auger again, there is smoke where the motor's pulley tries to turn the auger belts. I'm assuming something on the auger's side is stuck not allowing the auger pullies to spin with the belts/motor. After separating the auger from the motor, I use my hands to try to turn the auger but it won't turn. The auger and the auger pullies won't spin by hand. Maybe I'm not strong enough to give it sufficient torque? The next thing I can think of is to take the auger apart but I would like some insight or any suggestions before I do. Because I may be going the wrong direction. Any info/help is appreciated.
model 316e640f000
Received 0 Votes
Thanks.
Received 0 Votes
UPDATE: Well, I finally got around to working on the snowblower. Temps got up to the mid 20's this week. Anyway, there were nothing wrong with the auger itself. What was holding the auger from turning was ice. There were lots of ice behind the blades(?) that push the snow up out the chute(sp?). Basically froze the auger housing and the auger together. I separated the auger housing from the motor, took off the auger pullies and bang the area with the rubber mallet breaking the ice until the auger will spin.
Thanks hopkinsr2, aj-allen and doityourself.com.
