Tecumseh 10HP
Old 02-13-11, 08:26 PM
Tecumseh 10HP
I have a 5,000Watt Generator with a 10 HP tecumseh engine. It is approx. 10 years oil. I am having a run issue and suspect ignition. Anybody know whether this engine has points or electronic?
Old 02-13-11, 09:31 PM
BFHFixit's Avatar
Only 10 yrs old not likely...
If you could post a model number would help verify...
Old 02-14-11, 09:35 AM
Sorry--my ignorance got in the way of giving full details---It is a Tecumseh 10HP cast Iron Sleeve with model number HM100 159232K 3215D.
I have worked on small engines for over 50 years but I havent in the last 5 or so. I rebuilt the carburetor but had to use old parts because the ONLY number on the carburetor is 1074G3L. An extensive search reveals this number is invalid! I am looking toward ignition because the carburetor showed no signs of needing repaired.
The problem is similar to a lean carb. condition in that I have a lot of backfiring and adjusting the carb., or applying the choke, has little or no effect, other then the expected. A condensor or points could cause this problem.
Old 02-14-11, 09:44 AM
BFHFixit's Avatar
This manual covers your engine in detail.
Old 02-14-11, 11:12 AM
Thank you very much--this will certanily help.
Old 02-14-11, 07:43 PM
hopkinsr2's Avatar
Using the #'s you posted, I found it uses carb part # 632242 & it takes repair kit # 632347... Hope this helps,,,, Roger
Old 02-14-11, 08:11 PM
THANKS Roger----for the help!
Old 02-18-11, 06:13 AM
Roger---Could you tell me how you found these numbers. As I stated, I did a search using the engine number and the only number on the carb. and I came up with nothing?
I have ordered the carb. kit.
