Ignition Coil Help!!!
Old 02-22-11, 07:23 PM
Pictures by JohnPark85 - Photobucket
Hello, I am new to these forums. I stumbled across a group of 9 ignition coils. I have no idea what they will work for i have an album of 2 photos for each coil if you guys could help me identify them I would appreciate it so much!
Old 02-22-11, 07:36 PM
lawrosa's Avatar
Super Moderator
Looks like they are for small engines like a Briggs motor seen here.
B&S Engine Pointless
Mike NJ
Old 02-22-11, 11:50 PM
cheese's Avatar
The first 3 and last one look to be kohler or tecumseh, the rest are for briggs. What specific engines they fit is unknown without part numbers.
Old 02-23-11, 09:31 AM
Thanks I cant really find part numbers on them where are they located?
Old 02-23-11, 03:29 PM
cheese's Avatar
Usually they are stamped in thin paint/ink on the black part of the coil if I recall correctly. Sometimes you can clean them up and see it, most times it is gone.
Old 02-23-11, 04:39 PM
What happens if they are gone haha? Can the briggs coils match up to pretty much any smaller briggs like 2-10 hp?
Old 02-24-11, 09:57 AM
cheese's Avatar
No, coils are different on different size and model engines. A coil from a 3 horse doesn't fit on an 8 horse.
Old 02-24-11, 02:41 PM
Yeah ive heard you could re drill the holes is that true? Oh and i found a 4070 on the first tecumseh coil 7303 on another and 8712 on the other?? what does that mean?? I need one of the tecumseh coils to work on a 5hp
Old 02-24-11, 10:44 PM
cheese's Avatar
No, redrilling doesn't work because the curvature of the armature legs is different because of the different size flywheels they fit up to and also because the laminations of the coil make it very difficult to drill, and usually the holes are close enough that you would have to drill half the hole, instead of a new hole, which is nearly impossible.
Old 02-26-11, 02:31 PM
Oh ok well that makes sense. What about those numbers do they mean anything?
Old 02-26-11, 09:07 PM
cheese's Avatar
Not that I can tell.________________________________
