brggs isnt running correctly
kenkel's Avatar
MO
03-14-11, 04:22 PM   #1
I have recently bought a new 6.5 briggs ohv engine for a gokart i rebuilt. it isn't running like a briggs should. when i give it gas, i can't let off cuz it will die. i have to let it idle down slowly then let off the gas. its killing my brakes. the last engine that was on there was a briggs from the 90's and it won't die at all.
marbobj's Avatar
IA
03-19-11, 03:50 AM   #2
Stuff like that is usually the carburetor or the valve adjustments. Are you running a modified carburetor or stock that came with it? Also how does it idle once it comes down from the high rpms. If the idle is too low it will cause the dieing as well.
joecaption's Avatar
VA
03-19-11, 04:13 AM   #3
There should be two screws on the side of the carberator. Ones for high speed and ones for low speed. The low speed one needs adjustment.
cheese's Avatar
GA
03-19-11, 11:07 AM   #4
Could just be that the idle speed screw needs to be set.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
