bldgsuper (Adjust idle speed on Poulan Pro chainsaw)
Received 0 Votes
help with Poulan chainsaw
I have a Poulan Pro chainsaw PP4620AVX and need to adjust the idle speed, the screws are stacked and I cannot see the letters, L & H, does anyone know which is which?
The idle screw is separate from those 2 screws. If you want to adjust the fuel mixture, the low speed screw is the one closest to the engine and the high speed screw is the one closest to the air filter.
The idle adjustment is right where the linkage connects from the throttle on the side of the carb. There will be a small spring under a screw. It acts as a stop for the throttle linkage.
