John Deere mower died and won't start
Received 0 Votes
I recently bought a used John Deere Sabre mower. I had it out for a second mowing this friday. I used it for about 45 minutesand then the blade disengaged. I could not get it to re-engage. I turned off the mower, checked a few connections and started it up again. I mowed for another few minutes and then the blade disengaged angain. the mower started running rough like it would do if i stepped on the reverse pedal while the blade was engaged. I could not get the blade to engage again. The mower then died and would not start. It won't even give me an indicator light when I turn the key. I had the battery checked and it is good and will take a load. I have replaced the blade engagement swith as well. I have also checked the seat switch. No luck. I can't get anyone around hereto look at it for at least 2 weeks. I need to use it quickly for business. Any help will be appreciated!
Received 0 Votes
Had the same problem
Have a craftsman did the same thing. Turned out the pto would shut off when the tiny battery I had got low enough. I'd recharge the battery and I'd be good. I replaced the battery with an automotive battery and haven't had a problem since. I'm not saying the new battery fixed the problem. Maybe because it is such a large battery it can take a discharge for a longer time and I do enough work with it not using the pto it has time to recharge. Don't know.
