No spark again
I have 3 partner concrete saws I bought not running. My plan was to fix them and sell 2 and keep one. Anyways about a year ago when I bought them I couldnt get spark on any of them. Sometimes it would have spark and most of the time they wouldnt. I was away from home for a while and just got back so I started to dink around with them again. I reset the gap between the flywheel and the coil and it had great spark. I put it together and it had spark, fuel and compression but wouldnt even fire once. I checked the spark again and nothing. Is it common for these ignition coils to fail like this where they make a spark and then dont work? It drives me nuts and wears my arm out.
I have the wire pulled off to the coil that goes to ground so I know thats not the problem.
Would a plug have a problem that would cause this? Im not sure if I tried another plug the first time but Ill try it tomorrow.
I didnt get a chance to check it today, Ive been playing around in a septic tank for 2 days. I should have some time tomorrow.
I checked it out today, the sparkplug doesnt make a difference. It does make electricity just not enough to make a spark. I take it that means the coil is junk? I put on a different coil off another of the saws and it does the same.
I'll clean everything up tomorrow, I couldnt find the other coil. Ill find it tomorrow and try all 3. Maybe try another saw.
Well I cleaned everything down to bare metal so its grounded good and it didnt change a thing. I tried all 3 and they all do the same.
They are the 2 stroke concrete saws. They are all Partner K700. If I hold the end of the sparkplug wire and touch the engine I can feel a little electrcity.
If you're spinning the engine over fast while you hold the lead wire from the coil and your hand isn't shocked numb, you have a bad coil/module.
You need a couple of fast passes on the coil by the magnets to saturate the coil windings to get the voltage for a spark. For instance if you hold the lead wire while moving the flywheel magnets back and forth by hand you'll get a tingle and the coil may be good.
I bought a brand new coil for these saws and still no spark, could the magnet in the flywheel be weak? The new one does the same thing.
No the magnets would only go bad if subjected to alot of heat - like from a torch. Normal engine heat won't wreck them. You can demagnetize by other means, but the magnets aren't likely to be bad. A new module can be bad but It's more likely the way you're testing it or with the way you have it installed.
The magnets seem strong enough to me. I stuck the allen wrench on them and they stick together pretty well. Im at a loss with this. Maybe Ill send some pictures.
Buying a bad coil doesnt surprise me the way my luck goes.
Heres a picture, you can see the allen wrench stuck on the magnet. Im starting to wonder if the new coil is bad.
I had the same problem on a VG4D wisconsin and a electrical place that rebuilds magnetos said over time the coating on the wire inside the coil breaks down and they go bad.
Yes, an old coil can certainly go bad. Leave everything in place like you have it, take out the spark plug, stick a screwdriver in the spark plug wire. Then move the magnets just before the coil pickups. Hold onto the screwdriver and rotate the flywheel magnets completely past the coil, back and forth. See if you get any tingle from the screwdriver.
If this is with the new coil, the coil is likely OK. Make sure the gap between the coil and the flywheel is OK - about .010, dump all the gas out of it, spin it over about ten times without the plug in it and the throttle wide open. Then put a tablespoon of fuel down the plug hole, install the plug, then half throttle, no choke, pull it over a few times to see if it will fire. If it's semi flooded it may take a few pulls.
Previous Thread
Next Thread
