Sears 20 OHV B&S wont start, will fire on ether,wont run
Old 05-07-11, 01:13 PM
B
Neighbors Sears rider 20 OHV, have spark ,fresh gas fuel pump works , will turn over ......
will not fire , will fire on staring fluid in the carb. doest seem like its getting fuel in the carb to stay running.....
How do I clean the ports on this?
what else can we do..........?
Thanks
Tall Grass in Jersey!:
Old 05-07-11, 06:35 PM
3
It may have an anti-backfire solenoid on bottom of carb bowl that is not working.
Old 05-12-11, 11:38 PM
2
38racing is correct. Have you confirmed gas to the carb? I mean actually see a steady flow of fuel.
If so, remove the bowl. Does it have gas in it?
Hold your hand over the throat of the carb as you turn it over and see if it will suck some gas through.
If you can't get gas through and there is fuel in the bowl, rebuild or give it a really good cleaning.
Old 05-13-11, 05:29 AM
3
you might even be getting fuel to the bowl but the bad anti-fire solenoid might prevent it from getting into the fuel nozzle/jet.
