Honda EB3500 Generator Only Gives 1/2 Voltage
Old 05-15-11, 03:28 PM
B
I have an older Honda generator that only has about 3 hours of run time. It sits in my garage and I run it ever so often just to keep it running. It starts with the first pull of the cord. I recently started it and it only provides 65 volts to the receptacles. Serial number is EA6-3118823. Not sure what the problem is. Thanks for any help.
Old 05-17-11, 08:24 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
Is it running at the normal speed?
Old 05-20-11, 02:59 PM
B
I plugged a drill motor into the outlet and the engine does not speed up. Before when I would do this the engine would speed up and the drill seemed to operate at the correct speed. Also, the engine runs rougher than it did before.
Old 05-20-11, 06:09 PM
cheese's Avatar
I'm thinking the carburetor needs some cleaning and the throttle is stuck. Happens on generators a lot because they sit unused for such long periods of time.
Old 05-22-11, 07:14 AM
daswede's Avatar
Just a thought,maybe a blown rectifier diode,if they still use them.
Old 06-11-11, 04:09 PM
B
Thanks for the suggestions. I will try them.
