Rotor Tiller MTD 215-340-352 Engine Trouble
Old 05-22-11, 09:53 AM
My tiller is having engine issues. It only runs with the choke fully closed and when its in run mode. Sometimes it cuts itself off. I'm thinking it might be the carburetor, but when I mess with it, there is a lever underneath the filter box and when i push it full to its stop the engine increases its rpms to a more healthier sound. What should I do to tackle this problem? Clean the carburetor? Adjust the lever settings? Thanks in advance!
Old 05-22-11, 01:47 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
Don't move the lever settings, it is set from the factory and should never need to be moved again. The carburetor needs to be opened up and cleaned out.
Old 05-22-11, 05:39 PM
Thanks for the information...is that a fairly easy do as you go process?
Old 05-22-11, 07:06 PM
cheese's Avatar
Yes, very easy. Take the bowl off and clean every passage you can find in the carburetor and you'll probably have it fixed. Use automotive spray carb cleaner and a tiny wire to run through the jets.
Old 05-23-11, 06:38 AM
Hey thanks for the help with that! I'll let you know how it goes!
