troybilt tb20cs fuel line diagram
Old 05-26-11, 05:42 AM
does anyone know why my primer bulb does not fill when push in? Need diagram for fuel tank to primer and carb
Old 05-28-11, 11:33 PM
can anyone help, just tell me where the fuel lines go
Old 06-08-11, 07:14 PM
A
Clean your carb. That is most likely your problem. Route of fuel is from filter inside tank to connector outside and to bottom of carb. Through the carb and out top into prime pump and then into fuel tank. If connected correctly bulb sucks fuel through carb and back to tank.
Old 09-22-11, 09:21 PM
N
have you solved your issue?
