clutch repair on wheel horse 211-4
Old 05-26-11, 02:22 PM
Hi: My wheelhorse does nothing when I shift out of neutral. Forward or reverse - nothing. I know nothing about mowers and assume I will need a pro to fix this. Since I am assuming it is the clutch (I've been able to follow the "arm" back to the box like assembly under the seat ad it moves okay), my question is will this be such a costly fix that I am better off just looking for another used machine?
Thanks for your help.
Old 05-26-11, 05:29 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
Sounds like you are following the brake rod, which doesn't pertain to the problem. Under the mower frame should be a belt going to the transmission pulley. My bet is that this belt jumped off or broke.
