Craftsman riding mower won't start
Old 05-30-11, 10:44 AM
F
Have Craftsman model 91720512 6 speed, 42" cut, 14.5 Briggs & Stratton motor. Have replaced ignition switch, starter Solenoid. Was cutting grass yesterday, it was running fine and after running for about 1/2 hour, just dies like if you got off seat and safety switch killed it. Turn key, no click, no crank, obviously no start. It was late so called it a day, checked today and thought I found problem with a loose white crimp connector going to switch for clutch, it has a 4 pin block connector that plugs into clutch switch that clips into frame, 2 white wires, 2 black wires. Repaired connection, nothing! checked and replaces 30 AMP fuse, looked OK, checked battery voltage, fully charged 12.6 volts, checked wires for seat safety switch, they look OK What Next? Please Help Lawn is like a jungle!!! Suggestions to fix today???
Old 05-30-11, 11:28 AM
cheese's Avatar
Received 138 Upvotes on 127 Posts
Are the battery connections clean and tight? Is there power to the ignition switch?
