craftsman gas lawn trimmer
zrkk12's Avatar
CAL
06-03-11, 05:51 AM   #1
I have an OLDER trimmer, we had to replace the fuel lines in the tank, the bulb is now getting fuel, it still doesn't want to start even with starter fluid. I did notice, the lid to the gas tank has in the middle, a small check valve I believe that is fine until I pump the bulb for fuel then I get a good leak from the lid..check valve, then it doesn't start...thank you in advance if anyone can help.
cheese's Avatar
GA
06-03-11, 08:53 PM   #2
Check to see if it is sparking.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
jsouth's Avatar
TX
06-07-11, 09:18 AM   #3
Also check the compression with a gauge,must be at least 90# of compression or better to run.I like it to be 120#.Hope this helps.
Jerry
