Husqvarna 350 won't start
Old 06-10-11, 02:37 AM
V
Hello, I have a Husqvarna 350 - its a older model without a fuel primer bulb.
It has good enough compression - and after changing the spark plug, the spark looks great.
I try to start it up and I get nothing at all - I spray starter fluid into carb area - I still get nothing at all - I remove the sparkplug and I can still see some starter fluid "mist" in cylinder - so I know the cylinder is getting something.
I do have the compression release - its set correctly.
The only thing I can think of is even though I do have spark, maybe my timing is off.
Any ideas?
Old 06-22-11, 08:50 AM
must be, since you have a spark but no ignition
Old 06-22-11, 10:35 AM
V
Well, it turns out - I was wrong-. I play alot with lawnmowers - so my idea of good compression is not the same for a Chainsaw. On the Chainsaw I had mybe 80psi after many pulls. And after research I see around 150psi is good. I then removed my muffler and saw scoring on the piston.
I went to ebay and for $60 (shipping included) I got a piston,ring, bearing, and cyclinder head. I replaced them and it really wants to run now - I played with the low idle,fast settings to no avail - it idles, but now bogs down when you give it gas, the choke is in.
Old 06-22-11, 03:41 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
Sounds like the carb is the problem now.
Old 06-23-11, 06:54 AM
carb or clogged air filter could be the problem
