Is it the starter? Cub Cadet 2135 w/ Kohler Engine
Old 06-12-11, 02:04 PM
spirittoo's Avatar
Received 2 Upvotes on 2 Posts
Exclamation Is it the starter? Cub Cadet 2135 w/ Kohler Engine
I have the cub cadet 2135 ... I was unable to locate the engine serial number, they claimed it was on the right side of the engine blower housing, but they don't show where that is.:NO NO NO:
For a while the engine wouldn't start right off the bat ... I would get a series of mechanical clicking noise, after a few tries it would start ... well I tried to start it today ... got the clicking noise a couple of times then nothing ... I can't get it to start ... I turn the key and silence I get a amp light on the dash board ...
I tried cleaning the battery terminals with no result. So could it be the starter gone bad?
Anyway I can check it to make sure?
Old 06-12-11, 04:53 PM
hopkinsr2's Avatar
Load test the battery 1st,, If you have clicking noises, to me it sounds like a low voltage issue.. Don't measure the batt voltage with a voltmeter, Load test it to simulate operating conditions & post the results.... Roger
Old 06-12-11, 05:28 PM
G
Sure sounds like dead battery syndrome.
If you have jumper cables, try to jump start it from a car - engine off on car. If it fires right up, you have your answer - replace the battery.
Old 06-16-11, 02:05 PM
spirittoo's Avatar
Thumbs up Problem Solved :)
Hi ... you guys are right ... It was the battery ... used my jumper cable and jump the battery from my truck ... started right up ... thank God it was not the starter:NO NO NO: ... but have to get a new battery soon ...
Thanks ever so much for posting
