Chain saw fuel line
Handyman1950's Avatar
MO
06-22-11, 05:58 AM   #1
Chain saw fuel line
I have a Poulan chainsaw--about 15 years old. The fuel lines were rotten so I bought new ones--the plastic type. The primer bulb line was no problem. The line from the tank to the primer bulb has me stumped. It goes through a hole between the tank and the carb compartment. The hose being larger than the hole, a jam fit, is the only thing that seals the hole and keeps the fuel from leaking out. After going through the hole, it connects to a coupler and then another short piece connects to the weighted fuel pickup. I have been trying to get the tubing through the hole with no luck. I've tried cutting out a starter strip to get through the hole then pulling with longnose pliers but it breaks. Any help will be enormously appreciated!!
Vance
the_tow_guy's Avatar
FL
06-22-11, 07:20 AM   #2
I did that op on my old Poulan a while back. I think my solution was to cut the end of the tube at a very steep angle, that way you sneak up on the snug fit as you push the tube into the seal.
Measure it with a micrometer; cut it with an ax.
cheese's Avatar
GA
06-22-11, 03:48 PM   #3
Tow Guy has the trick. _______________
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
newtofta's Avatar
TX
06-22-11, 08:17 PM   #4
are you sure you have the correct size tubing?
there are a couple different o/d sizes
MO
06-23-11, 10:48 AM   #5
It's the right size. It has to be bigger than the hole so it will be a tight fit---that's the only thing keeping the fuel in. I cut it on a steep angle but if I cut it too long, it breaks when I pull on it. I just bought a pair of 12 inch, pistol grip, long nose pliers. I'm putting the slickest lube I have on the tubing. I'll give it another go and let you know the results.
Vance
