Need help!! No spark???
Old 06-24-11, 01:21 PM
Okay, I got one for ya... Running a Toro lawn mower, Briggs and stratton engine model number 286H77... turned it off, tried to start it back up ( 5 minutes later) and it won't start... backfires.. I take it apart and find the boot on the spark plug was cracked and bleeding the spark out. Replaced the boot, an now it won't spark at all! FN thing, replace the electronic aramature but I STILL can't get a spark. It seems pretty easy, engine turns, magnets run by arms, generate electric jolt and hits the plug.... right??? Anyone? Everything looks okay to me...
Thanks!
Old 06-24-11, 07:03 PM
cheese's Avatar
It's not quite that simple, but anyway, unplug the kill wire from the coil and see if it sparks. If so, there is something external killing the spark. If still no spark, then the coil is upside down, not gapped properly, or bad. If you used an aftermarket coil, it might be bad right out of the box, or if not, it might be bad next week. Never had luck using one that I recall.
Old 06-25-11, 05:06 AM
Well... I feel a little better. I did all that and the spark still eludes me.
I'll have to take it off and re install. Is there any "tricks" to the install? I have the gap card that comes with the part. AND it is a Briggs and Stratton part...
Old 06-27-11, 06:01 PM
Try taking out the wire from the boot and touch it directly to the engine block, see how that goes. It that works try to wrap the wires coming out of the spark plug wire directly to the top of the spark plug, see if the engine runs.
Enjoy!
Old 06-27-11, 10:26 PM
cheese's Avatar
No, don't cut your new coil wire up to wrap the wires on anything. There are no tricks, just make sure the coil is right side up (the kill wire terminal should be under the coil, not on top) and make sure the armature legs are .010" from the magnet on the flywheel. If it does not spark a good plug like this, with the kill wire unplugged, the coil is bad or the engine isn't turning fast enough.
